Re: Farmall 706 Ipto shaft question
Posted by P T Farmer on May 19, 2014 at 09:38:37 from (173.252.12.221):
In Reply to: Re: Farmall 706 Ipto shaft question posted by Owen Aaland on May 19, 2014 at 07:58:58:
Ok, that makes sense. I"ve had it apart before and just put in back the way it was but that doesn't mean it was right! When I look at the ipto shaft starting at the gear, I should have the gear, then bearing retainer washer(which I thought was a shim), then bearing, correct? Which way should the bearing be, the snap ring closer to the gear or bearing cage? Right now its closer to the gear and I wonder if the is enough room for the small snap ring on the shaft if the retainer washer is between the bearing and the gear? The bearing must move ahead on the shaft.
