It sounds like you have the bearing retainer washer on the wrong side of the snap ring on the bearing. When assembling the bearings onto to shaft the big retainer goes on the gear before the bearing. The bearing is located by the snap ring being held between the retainer washer and the front bearing cage. When the retaining washer is on the wrong side of the locating snap ring the IPTO gear can slide back against the TA carrier and the front seal will not be in the right location on the shaft.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
