Re: At my wits end with needle valves
Posted by Mr. Farmall A on May 20, 2014 at 05:57:21 from (68.32.185.8):
In Reply to: At my wits end with needle valves posted by mkirsch on May 20, 2014 at 04:56:33:
I think it is both bad gas and bad needle valves that can't take it. Over the winter I have to drain the gas out of my stuff because the ethanol phase separates in the fuel tanks with open venting otherwise. I know this from experience. Doesn't do it in the gas can when sealed up tight. I am using the triple baffle safety gas cap if that makes a diffference? However the new needle valves are pretty lousy since they can't take carb cleaner without failing.
