Posted by wfd2 on May 20, 2014 at 14:32:01 from (72.104.71.144):
Hello,
I have a '73 656 diesel utility w/standard transmission. In one of my costly forgetful moments, I neglected to put the dipstick back into the transmission after using my post pounder. Oh, and it rained on/off for a few days before I found that the oil filler tube was open. I am sure water got into the system, I just don't know how much.
The good news (if there is any!) is I didn't start the tractor. I didn't want the water pumped through the entire system.
So, here's what I'm going to do:
1. Drain the oil from the system using the 2 drain plugs in the transmission below. (I'm going to change the hydraulic filter too because I needed to do that anyway).
2. Since I did not start the tractor, I don't think I need to drain the hydraulic housing, just the transmission because water settles to the bottom and the filler tube on the transmission was the only source of contamination.
3. Then, I'm going to add new hydraulic fluid and get on with my life.
Any opinions on whether or not this should be sufficient in removing most if not all the water in the system?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
