Re: 656-D Utility water in transmission hydraulics
Posted by mkirsch on May 21, 2014 at 05:12:39 from (65.199.189.6):
In Reply to: 656-D Utility water in transmission hydraulics posted by wfd2 on May 20, 2014 at 14:32:01:
The water will settle to the bottom. If the oil is fairly new you could simply drain off the water until clear oil comes out, then top off the oil again with fresh stuff.
Of course if it hasn't been changed in a while, it's a good idea to change it.
There is no separate "hydraulic housing" on the tractor, unless you mean on the post pounder itself.
I really doubt that any significant amount of water got in. Milky oil is due to water that's been in there and circulated.
