Re: valve stems on H rear rims
Posted by C1802362 on May 20, 2014 at 18:50:22 from (72.221.74.219):
In Reply to: valve stems on H rear rims posted by c1802362 on May 20, 2014 at 14:25:26:
Am I embarrassed!
Tonight I went out to the barn and took a good long look at the rim. I looked closely at the bad weld patch, then thought to check it with a magnet. Sure enough, the rim is steel, but the "weld" is actually putty. When I chipped it off I realized it was covering a large hole in the rim next to the hole the tube stem comes through. I could see clear through to the tube.
It is obvious calcium was in the tube at some point and ate its way through the rim.
So, now I need to get the rim/tire off, the tube and tire dismounted, then blast the rim clean, weld in a real patch over the hole and repaint before getting a new tube.
Sorry to exercise everyone...
Art
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
