Re: M leaks
Posted by Janicholson on May 20, 2014 at 19:16:39 from (74.60.94.18):
In Reply to: M leaks posted by Johnny Meloy on May 20, 2014 at 19:04:08:
The gear box is meshed with the trans input shaft/gear the thickness of the original gasket, and or shims if any determine the depth of this meshing. If too thin, it will make radical noise as the teeth bottom on each other. If too thick they will make whine noise and be less strong. So measure the thickness of that gasket setup and keep it the same when reinstalling the unit. I would use a thin but even coating of #2 non hardening Permatex on the surfaces. It will wipe off with denatured alcohol if cleaned early. There are 6 bolts holding it on, leave the middle (long) bolts in place till it is out because they hit the tank. Jim
