SEEMS YOU STILL HAVE A MAJOR PROBLEM. I WOULD LIKE TO SUGGEST THAT YOU GET YOU A CLEAN METAL GAS CAN,TAKE TO SOMEONE AND HAVE A CONNECTION SOLDERED IN THE BOTTOM OF CAN, CONNECT A RUBBER TEMP HOSE FROM THE CAN DIRECTLY TO THE CARB WHEN YOU INSTALL A NEW VALVE. FILL WITH SAME FUEL YOU CURRENTLY USE, AND LET SET A FEW DAYS. SEE IF YOU HAVE THE SAME PROBLEM WITH THE TEMP GAS TANK CONVERSION. IF EVERYTHING OK, WOULD SUGGEST YOU FIND ANOTHER TANK FOR YOUR TRACTOR. ON LOTS OF RESTORES, IF REGULAR GASOLINE OR TRACTOR FUELS SET FOR ANY LENGTH OF TIME, THEY WILL PRODUCE AN OILY AND TAR FILM IN THE BOTTOM OF TANK.; NOTHING WILL REMOVE THIS FILM FROM THE OLD TANK. I HAVE DONE MANY RESTORES THAT SET FOR YEARS, AND FIND LOTS OF THEM WITH TAR BUILDUPS AS MUCH AS ONE INCH OR MORE THICK. I HAVE EVEN REMOVED THE TANKS FROM THE OLD TRACTORS, TURNED UPSIDE DOWN ON A BRUSH PILE, AND MELTED OUT THE TAR ADDATIVES, THEN PUT A LIQUID LINER IN TO SEAL ALL THE PITS AND RUST THAT OCCOURED FROM THE HEAT.(DO NOT ADVISE THIS),BUT HAVE DID LOTS THIS WAY.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
