ALSO, WHEN YOU ARE CHANGING THE NEEDLE VALVE, ARE YOU CHANGING THE SEAT ALSO. THE PROBLEM MAY BE SIMPLY WITH YOUR SEAT. GET NEW VALVE AND SEAT AND INSTALL BOTH. I HAVE THIS PROBLEM MANY TIMES SIMILAR TO YOURS, BUT FIND THAT THERE IS NOTHING WRONG WITH THE FUEL. IT IS A SIMPLE PROBLEM THAT YOU ARE MISSING. ALSO, THIS TYPE CARB HAS AN ELBOW THAT SCREWS IN WHERE THE GAS LINE CONNECTS,BEHIND THIS ELBOW,THERE IS A SCREEN MADE ON THE ELL FROM THE FACTORY, THAT MAY BE TOTALLY CLOGGED WITH THE OILY SUBS THAT YOU ARE GETTING, AND AS FUEL PASSES THRU, WILL DEFINETLY STICK THE NEEDLE. MOST EVERYONE NEVER REMOVES THE ELBOW, JUST THE GAS LINE THAT SCREWS TO THE CARB.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
