Re: 200 still running rough and VERY hard to start
Posted by clint s on May 22, 2014 at 19:05:02 from (67.242.45.169):
In Reply to: 200 still running rough and VERY hard to start posted by BONO ANTIQUE TRACTOR on May 22, 2014 at 18:44:05:
Sounds good. To answer a few ? It is 12v. Coil is the Napa IC14sb 12 volt which has an internal resistor. Condenser is new. I have had carb apart 2 times in the last weeks, cleaned all passages with a small wire and soaked down good with carb cleaner and blown out. Float is in good shape although I did not set the float. Decent stream a gas coming out of the bowl when plug removed of the carb. Mixture screw is turned out 1 turn from seat. There may be a leak between the manifold and the carb as it does look wet sometimes when it floods.
The coil tends to get pretty hot too.
I tried a different coil on it, BUT it was not new and probably on my shelf, for a reason. It was not a known good coil. There was a resistor with it so IIRC it was probably the original 6 volt coil that could have be 60 years old
I will make a new gasket for that this weekend and try a new coil.
