Re: Rear Tires diffrent size
Posted by SDE on May 24, 2014 at 19:49:47 from (184.157.219.125):
In Reply to: Rear Tires diffrent size posted by Meangreen on May 24, 2014 at 14:28:30:
Are both rims the same width? If so, one tire is not matched to the correct rim width. That should determine which tire to switch. If the the rims are the correct width for each tire, you would then want to swap the rim and the tire out as a unit. Just make sure that the replacement rim is the same type that you are replacing. Not all rims will fit with the same clamps.
SDE
