Re: F12 Power Lift Pump
Posted by DC Snider on May 28, 2014 at 04:26:30 from (74.47.73.171):
In Reply to: Re: F12 Power Lift Pump posted by FBH44 on May 27, 2014 at 07:29:36:
I pulled the shifter late last night, with the shirfter in the "neutral" position. The rails are lined up. I can see with a flash light that the spline shaft is locking up so to speak. When I try to turn the belt pulley it will just rotate back and forth ever so slight. The transmission is in neutral, nothing else is even attempting to move. I guess I'm gonna have to pull that pump again and see where I went wrong. Something has it bound up...
