Re: F12 Power Lift Pump
Posted by John M on May 28, 2014 at 08:14:46 from (68.115.194.228):
In Reply to: Re: F12 Power Lift Pump posted by DC Snider on May 28, 2014 at 04:26:30:
The only thing I can think of is the "nut" isnt
engaged to the pump, or possibly when you tighten
down the unit to the trans top , assuming you did
that with the pipe attached, its putting some down
pressure on the pump some. Seems like I had to shim
the lift unit to get my pipe to fit right. I think
the book shows a gasket(s) for that pipe, but I just
used silicon since the space was real tight.
