Re: 1953 Super C - Only runs with full throttle (lever all up)
Posted by jhilyer on May 28, 2014 at 13:22:26 from (74.81.112.46):
In Reply to: 1953 Super C - Only runs with full throttle (lever all up) posted by bthomas67wagon on May 28, 2014 at 10:10:03:
Just this weekend my son and I got our 53 or 54 Super C running(it's got Fast Hitch, so I think that makes it a 54). It sat there for 5 years while I used other tractors. It's got several issues, one of which was the carb - I took the carb off, disassembled as much as I could, cleaned it with Mass Airflow Sensor cleaner because that's what I had, and put it back together.
It's a Zenith. Local TSC store didn't have a rebuild kit for it. I checked the floats for pin holes, and a previous owner had stuck a bolt and washers in the bottom for a plug with some sort of sealant - I resealed with form-a-gasket.
My point is, I did basically nothing to rebuild this carb, just a good cleaning, and it ran. Purred, even. A couple few turns on the one adjustment screw on the outside- I don't even know what it does.
I can't imagine what your problem is if the throttle is "all the way up" to run. Is it choking out?
Interesting that we're both working on a Super C at the same time.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
