1953 Super C - Only runs with full throttle (lever all up)
Posted by bthomas67wagon on May 28, 2014 at 10:10:03 from (66.145.208.166):
So, now that I have the tractor "running" I'm going to start tweaking it and getting it to run right and be reliable. Since I really don't have history on this tractor, there are certainly some things I have ??? on.
The prior owner has a C-clamp holding the throttle lever all the way up and if I move it down a notch or two, it stalls out. Carb?
I'm going to pull the carb and rebuild it this weekend and will take a closer look at seeing how good or bad the carb is.
What are the initial settings on the Zenith Carb?
2 1/2 turns out from full seat on the main jet?
1 1/2 turns out from full seat on idle needle?
Float = 1 3/8 or 1 5/8?
Was there another adj screw I saw some place?
Thanks!!
-Brent
