Re: where to order needle bearings for the C governor
Posted by Rick Remmert on May 28, 2014 at 17:32:26 from (68.103.4.23):
In Reply to: where to order needle bearings for the C governor posted by SDE on May 28, 2014 at 15:07:54:
I just went thru mine last year. The part number for the bearing is a 43481D. Price was $30.92. I also put a new spring in it while I had it apart. The fastest I could get it to run was about 1,500 RPM. I use this tractor to pull with and do a little rotary mowing with it. Someone on here suggested to put a "504" spring in it. I got one 369686R2. It was $8.64. It made that tractor come alive. It is now stopped at 1,950. When I mow, I only run it about 3/4 throttle. All the parts came from my local IH dealer.
