Re: 1953 Super C - Only runs with full throttle (lever all up)
Posted by Rick Remmert on May 28, 2014 at 18:02:13 from (68.103.4.23):
In Reply to: 1953 Super C - Only runs with full throttle (lever all up) posted by bthomas67wagon on May 28, 2014 at 10:10:03:
Make sure you have "good in a can that you can see" fuel flow from the carb end of the fuel line. Remove the oil cup on the air cleaner and make sure you don't have a mouse nest or something in it or the cup is plugged with dirt. Hold your hand over the end of the air intake when it is running to make sure it is getting air. Look at the easy stuff first. If it still does not run, post again. It is amazing what they can figure out on here.
