Re: Super c camshaft stripped
Posted by White halftrack on May 29, 2014 at 01:06:14 from (174.238.100.66):
In Reply to: Re: Super c camshaft stripped posted by Bob on May 28, 2014 at 18:43:37:
Yes. Gravity would be working against me. Would a heavy grease do the job or a rubber band to a dowel stick? Is it doable with engine in? Obviously push rods removed
Thanks.
