Re: Super c camshaft stripped
Posted by Bob on May 28, 2014 at 18:43:37 from (75.234.75.69):
In Reply to: Re: Super c camshaft stripped posted by White halftrack on May 28, 2014 at 15:35:05:
No matter WHAT you chose to do, if not tearing the engine down, you will need to lift and restrain the tappets upward in the block to facilitate camshaft removal.
