Re: need some engine rebuild advice
Posted by Traktrmn on December 25, 2000 at 18:24:15 from (216.179.0.5):
In Reply to: need some engine rebuild advice posted by MikeH-Tx on December 23, 2000 at 14:33:42:
I'll tell you what happened with me and my F20.
After thoroughly cleaning the grooves on pistons,
I installed the new set of rings. No parts from
the old set....! Are your caps on the same rod
they came off of? Are they on in the same direction as when you removed them? What did you
torque the rod bolts at? If the the 12 is like the 20, you can do all the rings and rods from the bottom. Good luck.
Post A Followup
: Re: Re: need some engine rebuild advice
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
