First off if it is a gear drive it will hold about 11 gallons and oil level is checked with engine shut off. A hydrostatic drive tractor will hold 15 and is checked while engine is running for at least a few minutes to fill hydrostatic case. It drains back when shut down and shows over full. Now as far as fluid coming down from the top inside, it should not. The return flow from pump or pumps is directed through that pipe and hose directly back into the main suction tube in bottom of rear. Either you have a broken hose, tube, blown O-rings or relief valve is stuck open for oil to come down from top when no valves are dead headed. If steering works good, main pump is ok.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
