Re: 656 Loader Problem Update
Posted by Scott(MO) on May 30, 2014 at 16:14:01 from (173.186.177.216):
In Reply to: Re: 656 Loader Problem Update posted by pete 23 on May 30, 2014 at 10:12:08:
That"s interesting about the gallons of oil it holds. My Case/IH Manual says Gear Drive Farmalls hold 16 gallons and the Hydrostat Drives hold 20 gallons. So, the manual must be wrong because with the engine off, it"s full at 11 gallons. I"m also glad to hear about the main pump. Now if I could just track down where the problem is. Thanks for the good info Pete. This helps a bunch.
