Re: IH 2400b with D179 starting problems
Posted by jimb2 on May 30, 2014 at 12:53:27 from (99.240.243.222):
In Reply to: IH 2400b with D179 starting problems posted by Charlie Yancey on May 30, 2014 at 07:03:48:
Hi Charlie, my guess it is 180* out of time. The Bosch pump only turns at 1/2 the speed of the crankshaft so to correct the problem, scribe a mark on the pump gear to the drive hub, next remove the 3 cap screws from the slots in the pump drive gear and rotate the drive hub 1 revolution in direction of normal rotation and align scribe marks and re-install cap screws.
Like someone else mentioned when the timing marks are all aligned the key way on the pump drive shaft should be at 11 o'clock but it still can be 1 revolution out of time.
JimB
