Re: IH 2400b with D179 starting problems
Posted by charlie yancey on May 31, 2014 at 05:20:07 from (72.12.78.150):
In Reply to: Re: IH 2400b with D179 starting problems posted by jimb2 on May 30, 2014 at 12:53:27:
The pump turns counter clock wise...Right? Should the pump spin freely or be rather hard to move?
Also if it does spin counter clock wise, how would I rotate it at all?
Mine Injector pump hub will not move within the gear.
