Re: starting a 234 international compact tractor
Posted by Glennster on May 30, 2014 at 17:14:19 from (99.90.9.201):
In Reply to: starting a 234 international compact tractor posted by rustytenn on May 30, 2014 at 10:13:50:
I worked on a friends 254. You should be able to jump around
the ignition to get things working. It needs the glow plugs to
start. Also, when you turn the ignition on, it activated a fuel
solenoid on the right side of the engine by the pump to turn the
fuel on. You will see a plunger move. On the dash at the lower
right of the steering wheel is a small chrome disk with holes in
it. Inside is a coil of wire that glows red after a few minutes to
show the glow plugs are working. Also, there is a park position
on the range selector on the left side of the tractor. It needs to
be in park, and the clutch depressed for the starter to work.
Hope that helps.
