starting a 234 international compact tractor
Posted by rustytenn on May 30, 2014 at 10:13:50 from (137.119.138.107):
I may be able to purchase a 234 international tractor from a relative whose husband has past away recently.the tractor has sat for at least 3years.it's in rough shape but I believe it did run when it was parked.the key switch has not worked for years and it was crossed out to start it each time.I put a battery in it and it turns over fine and smokes a little out the exhaust like it is getting fuel but not sure if it's getting fire or not.Without buying a key switch(until if I buy it)how can I check if it's getting fire?is there a wiring diagram that anyone knows about online?Thanks
