Re: IH 2400b with D179 starting problems
Posted by charlie yancey on May 31, 2014 at 05:15:49 from (72.12.78.150):
In Reply to: Re: IH 2400b with D179 starting problems posted by Bob M on May 30, 2014 at 10:47:15:
So last night I was able to check the timing and it was off. I have the engine on 14 degrees (as close as I can tell, no pointer).
Problem now is the Hub that attaches to the injector pump is not wanting to move within the gear. It seems really tight. Also, do I just tighten down the hub nut all the way and keep spinning it until the mark in the timing window of the of the injector pump lines up?
Pump does not spin smoothly but "clicks" as it moves from position to position. I really hope I dont have to get a new pump or take the timing cover all the way off.
Thanks again for all the help offered.
