Do you get white "smoke" out the exhaust while cranking? If yes the problem's a timing issue.
However if nothing's coming out the stack no fuel is being injected. Most likely cause is a bit of air trapped between the pump and the injectors. The first thing I'd do then is go through the fuel system bleeding process, following the manufacturer's directions EXACTLY.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
