Re: Injector pump problems international 454
Posted by Dieseltech on May 31, 2014 at 08:39:20 from (199.16.223.2):
In Reply to: Injector pump problems international 454 posted by MAH on May 31, 2014 at 05:27:49:
The open bolt is at the inlet at drive end of the pump. The restricted bolt is at the top, return line.
