Posted by MAH on May 31, 2014 at 05:27:49 from (71.83.74.137):
Hello, I have international 454 that has always cranked and run real well. I started getting diesel in the crankcase so I took it off and had seals put in the pump. I put the pump back on and now it won't start. I talked to someone and they said might need to take pump off and turn pump revolution. Also, the guy that worked on my pump said that the two lines one from filter and the other on top of pump. He said that you need to make sure you put the bolts that hold the lines are put in the same place they come out. One of the bolts has a bigger hole up through the bottom than the other. Can someone tell me which one goes where? In case I have them mixed up.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
