Re: timing on my farmall 300
Posted by wayne in mn on May 31, 2014 at 17:15:54 from (71.8.150.168):
In Reply to: timing on my farmall 300 posted by bill gaw on May 31, 2014 at 10:17:12:
Just a tiny bit of grease on the weight pins. A bit of grease on the point rubbing block. If you removed the shaft grease it before re-assembly.
