Re: cub carb problem?? or governor?
Posted by DGinVT on June 01, 2014 at 05:34:04 from (99.196.32.58):
In Reply to: cub carb problem?? or governor? posted by BruceS. on June 01, 2014 at 04:30:27:
MY cub had a similar problem and you might have loosened a bunch of rust in the tank that has plugged the filter. Open the drain in the bottom of the carb and see if you are getting a good flow. If not you may have to flush the rust out. I have an inline transparent filter in my system so I can see what is happening. To improve my operation I got a Zenith carb off this site and it has worked well ever since. This was a considerable improvement over the original IH. carb.
