Posted by BruceS. on June 01, 2014 at 04:30:27 from (24.161.35.129):
I have a cub with a complete engine rebuild. Ran great until the other day when I hit a bump while mowing. Tractor started missing and popping thru exhaust. Discovered that a carb mounting bolt had stripped and was letting air in. Fixed that with a helicoil and new gasket. Tractor continues to run poorly (won't idle and runs unevenly). Will run even tho idle adjustment screw is all the way in. I reset the carb to gov. rod, but made no difference. One curious observation which COULD be the problem: There is visible movement of gas in the sediment bowl, even a tiny space between gas and top of bowl, which comes and goes. Is that a factor with this problem? Sorry for long post. I can't seem to solve this one. HOpe somebody will/can help. BTW, carb was taken apart and cleaned with carb cleaner and some fine wire, but I did not take the jets out.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
