I agree, check the flow. If good, make sure the points are set to .020" if coil ignition, or .013" if mag. The presence of a bubble in the bowl is typical. If you go with a filter in the line, (not generally recommended) use a filter designed for gravity feed systems. The small plastic filters can restrict flow and look clean. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
