The diode trio is bad. Since you can get full output with 12 volts applied to #1 terminal the rectifier bridge diodes are probably OK.
The internal connection to charging voltage on the #1 terminal is from the diode trio. The only power you have going to the rotor is through the indicator lamp so you only have a small amount of magnetism and low alternator output.
10SI regulator schematics
This post was edited by Owen Aaland at 18:31:29 06/03/14.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
