Posted by mike1972chev on June 03, 2014 at 17:45:32 from (108.67.91.56):
Well I have to say I am a little stumped on this one. :( I have a 10 SI Delco alternator on my 580 Case backhoe (I know NOT I.H.,but its in the "family" :) SAME hook up as many: The "BATT" terminal is coming straight from the battery,the #2 terminal on the voltage reg is coming right from the "BATT" terminal and it seems as I have traced back to the key switch,the #1 terminal hooks to the "ACCESORY" terminal on the key switch to "trigger/excite"the alternator.
OK,NOW for what the problem is: When I start the tractor,the "alternator" idiot light is glowing on the dash panel.The alternator is putting out SOME,but not fully charging.(I DO NOT have a voltage reading at the battery ,but the magnetic pull on the bearing at the back of the case is SLIGHT pull on my screwdriver.) When I stick a test light into the #1 wire terminal at the alternator with it UNPLUGGED ,the test light glows BRIGHT. When I probe the #1 wire at the alternator with it PLUGGED IN,it glows VERY DIM.
If I take a jumper wire from the "BATT" terminal to the #1 terminal on the voltage regulator,the alternator idiot light goes out and I can tell it is goes back to fully charging the battery.It "sparks" when I touch the jumper wire from the "BATT" terminal to #1 and the magnetic pull on my screwdriver is STRONG!! SORRY,no voltage readings. :(
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
