Re: 200 STILL hard to start
Posted by clint s on June 03, 2014 at 19:11:45 from (67.242.45.169):
In Reply to: 200 STILL hard to start posted by clint s on June 03, 2014 at 18:03:59:
[quote="Janicholson"](reply to post at 18:32:16 06/03/14) [/quote
Thanks that makes sense for the pop. Did check spark at the plugs and it "seemed" OK but who knows. Dealing with alot of old wiring so I will check cranking voltage tomorrow after the battery charges.
Will do as follows if I read the above right: Disconnect the wire that runs from the - (negative) post of the coil to the distributor and ground it, then check cranking voltage at the + (positive) post of the coil.
Will do tomorrow
