Use a hydrometer and check the specific gravity of each battery cell and compare the readings. Should see a reading of 1.280 on a fully charged battery. If one cell reads real low you need a new battery. Also check your charging voltage across the battery terminals with the engine at 1/2 throttle or better. Should see around 14 volts using a volt meter. Hal
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
