Re: 10 SI Delco Alternator issue(ATTN JANICHOLSON/JOHN T)
Posted by mkirsch on June 04, 2014 at 05:14:00 from (65.199.189.6):
In Reply to: 10 SI Delco Alternator issue(ATTN JANICHOLSON/JOHN T) posted by mike1972chev on June 03, 2014 at 17:45:32:
Two questions before you get out the soldering gun:
1. Did this work before?
2. Is the accessory terminal on the switch getting power with the key in the ON position?
I think if you answer yes to #1, you can get out the soldering gun.
