Re: 10 SI Delco Alternator issue(ATTN JANICHOLSON/JOHN T)
Posted by John T on June 04, 2014 at 06:06:40 from (216.249.72.121):
In Reply to: 10 SI Delco Alternator issue(ATTN JANICHOLSON/JOHN T) posted by mike1972chev on June 03, 2014 at 17:45:32:
I have to take a few guesses here. If the idiot light is wired one side to ign so its hot when key is on and other side to the alternators little No 1 terminal (works also to supply excitation voltage plus prevent run on like if a diode is used) yes it works and glows as it sees a ground via the alternator when its not running as Jim better explained. As long as the No 2 sense voltage wiring is good and the ground is good, if the light glows dim when running Id suspect an alternator internal problem such as its internal regulator or diodes or slip rings etc but I cant say for sure just what....
John T (NOT an Alternator expert, Im only DC certified lol)
