You need to make a mark on the body of the mag where #1 wire goes to the plug. Now remove the cap and turn the engine over till the rotor stops at that position if the rotor doesent stop at the mark you need to remove the cover where the gears are that turn the rotor and line up the rotor so it is on that mark when it stops just before it snaps and your engine will start good with the crank as the mag fires on TDC you dont want the rotor snaping before or after the mark. That will solve your cranking problems and kicking back ect.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
