That voltage is at the low side of OK. A 200 should crank like no- body"s -business. Check the battery cables. They should be 2 gauge or better to be carrying enough amps. One way to see if it is cable related is to run a jumper cable on both the hot and ground side of the battery to the starter (hot to the starter switch, and ground to the starter bolt to chassis. This effectively increases the cable size without purchasing new till the test proves the need. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
