Re: 200 STILL hard to start
Posted by clint s on June 04, 2014 at 17:01:21 from (67.242.45.169):
In Reply to: 200 STILL hard to start posted by Janicholson on June 04, 2014 at 16:21:36:
As far as the starter cranking it does crank really fast without an issue. I will check the cables clean them up. The cables at least #2 BUT the cable ends are the ones where you just tighten the cables in with 2 bolts like this
http://www.amazon.com/Schumacher-BAF-TTC-Coated-Terminal-Washer/dp/B0060YHLHU/ref=sr_1_20?ie=UTF8&qid=1401926266&sr=8-20&keywords=battery+terminal+ends
I will get new ends and solder them in when I get a chance.
Still thinking this could/may be carb related either to littel or too much gas but at this point who knows
