The Kettering system has points allow the coil magnetic field to build and then, when the points are opened by the distributor cam, the magnetic field collapses and a large voltage (20 kV or so) is produced. The capacitor has two functions: 1) it absorbs the back EMF from the magnetic field in the coil to minimize point contact burning and maximize point life; and 2) it forms a resonant circuit with the ignition coil transferring further energy to the secondary side until the energy is exhausted. the high voltage circuit is "grounded" to the battery through its internal connection (in the coil) to the primary winding. That winding is connected to the ignition primary wire from the ignition switch and through the above mentioned resonance with the condenser. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
