Re: 200 STILL hard to start
Posted by clint s on June 04, 2014 at 19:05:15 from (67.242.45.169):
In Reply to: 200 STILL hard to start posted by Lmack on June 04, 2014 at 18:51:11:
I have been fighting this issue for a few year now, but it has gotten worse this year. At first it would not start only a few times a summer. Last year during haying it world be worked every other day or so the whole summer raking and tedding hay. Could work fine for a day or a week with no issues then stall and not start, shut it off and no start or go to start in the AM and tough start. Let it sit for a few hours and it would usually start and run fine for a day or a week. Because of this I do not think it is a fuel condensate issue. Bowl and site glass drained several times already this year.
12 volt coil no resistor required does NOT need a resistor between Coil and distributor right..........
ie you will not burn up the "6 volt" points with a proper 12 volt set up
