Re: Hand-start 39 Farmall A
Posted by NNP on June 05, 2014 at 04:37:06 from (66.66.112.196):
In Reply to: Hand-start 39 Farmall A posted by Mo in NE Tx on June 04, 2014 at 14:52:50:
when I'm timing tractors that will be crank started occasionally, with marks far away from the crank handle....
#1 TDC compression, find the mark underneath, align it,
mark the front pulley and cover with a paint pen to correspond.
Time the mag by the book moving it till it snaps.
Now with the plugs out turn the crank handle slowly, watching your paint marks to verify, under engine actually turning situation.
When the paint lines meet, and the snap is right on em, you are good, for #1 and next turn #4.
Start it up and clip your timing light on #1 wire, to verify that your marks are now offset some to make sure the advance is working.
This post was edited by NNP at 04:43:17 06/05/14.
