Re: 300U hydraulic very hot ??
Posted by pete 23 on June 05, 2014 at 09:54:44 from (74.33.89.136):
In Reply to: 300U hydraulic very hot ?? posted by 300dave on June 05, 2014 at 09:06:10:
No, this is not right. Your system is staying on high pressure all the time. That is why it is getting hot and also why engine rpm increases when using cyl as what ever you are operating with the cyl takes less pressure than the pressure system is staying on when it is supposed to be in neutral. First make doubly sure none of your single to double setting are moved too far. Bent or broken pin. If they are ok, something is wrong in regulator valve. Gasket covering hole, orfice not open or something misassembled. A gauge right in the side of the regulator block will quickly show you what you have. One at coupler will not show bypass pressure which should be well under 100psi.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
