Re: 300U hydraulic very hot ??
Posted by 300dave on June 05, 2014 at 15:27:45 from (50.48.62.243):
In Reply to: Re: 300U hydraulic very hot ?? posted by pete 23 on June 05, 2014 at 09:54:44:
OK just to be clear, when using cylinder to lift, is like taking a big load off engine-rpm goes up, but it sounds better, more relaxed: less load.
So-single to double settings? means what? ???
exactly...?
all pins seem ok, assuming you mean external;all good, greased
"side of regulator block" means on the narrow side ,I assume, where there is a plug?
And "coupler" ? I have 1 cylinder and 1 valve box, and 1 regulator box. Hoses go direct from valve to cylinder.
tx again
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
