Re: H Water pump
Posted by David G on June 06, 2014 at 07:36:04 from (205.215.206.18):
In Reply to: H Water pump posted by VeryOldJack on June 06, 2014 at 06:52:15:
I bought one from this site that had a loose gland nut also. I would make sure it is packed, tight and have a drop of loctite on it.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
