Posted by VeryOldJack on June 06, 2014 at 06:52:15 from (24.220.77.115):
I purchased a new water pump for my 1940 H and it arrived with the gland nut loose on the shaft. I'm assuming that I have to add graphite packing to this unit and then tighten the nut. Can someone tell me about this before I make an expensive mistake? The impeller drive studs were not included with the new pump so I priced them at the local Case/IH dealer. Can you believe $57.00 plus change for each one and $6.22 for each spring? Since the old ones were pretty badly worn I intend to make new ones using grade 8 bolts and 75 cent springs I found at my local hardware store. I'm not restoring the tractor, I'm using it for work. Does anyone have a reasonable objection to my stud/spring solution? Please give reasoning. I could use softer studs if necessary. (Grade 5 or less.)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
